跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36471 个问题 查看全部
Screen flashes red when trying to recover with iTunes 4013/4014 error
When i boot up the iPhone 6 Plus I get the message to connect the iphone to itunes. I've tried recovering it with itunes but get the error codes 4013 and 4014.
Sometimes when recovering with iTunes the iphone flashes a red screen before rebooting again to an apple logo and then again: connect to itunes screen.
I've read some possible fixes on this forum: to remove the camera connector from the motherboard and starting up. I have done this (removed front facing camera and the main camera) but with no luck. I have the same red screen flash as before.
What could i do to fix this problem and have a working iphone again?
More information:
  1. Inside a few screws were missing (5 or 6)
  2. The waterdamage strips didnt recolour so no water damage as far as i see
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
it could be long screw damage or it could be the frontal camera. I check that out first though to see if there is any structural damage to the logic board
这个答案有帮助吗?
得分 2
1条评论:
Which one do i check out first? The frontal camera or for long screw damage? Should I just disconnect it and try to boot up again or should I order a new one.
I have tried to disconnect the frontal camera from the motherboard before and try to restore it again but the results were the same (not booting, red flash).
完成的
添加一条评论
maybe there are some problem in the connection between your iPhone and PC, which cause you coun't recover your deleted data through iTunes. so how about trying to use a data recovery toolkit, such as iPhone data recovery, to assist to deal with this problem. if you could connect your iPhone to PC wiith USB, so you could recover your data. Actually, I also have suffered the same problems before, but luckily, I had got my deleted data back.
Read the following article to get more details about this method if you need. I hope it will work for you, too, and you could successfully. Good luck to you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 656
