跳转到主内容
Smart phone compatible wrist watch. Released 2013, model number MV100
4 个问题 查看全部
The analog watch doesnt seem to be keeping time.
The analog section of the watch doesn't seem to be keeping time, it won't move or tick.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
student iFixit Technical Writing Project
完成的
添加一条评论
1个答案
已选择的解决方案
The analog section of the watch runs off of its own battery independent of the battery that powers the smart watch so you may need to change the small watch battery itself. The crown also may need to be fully inserted. The crown is the small circular winding bit off to the side that you use to set the analog time. After changing the time you need to press it in so that the watch ticks.
这个答案有帮助吗?
得分 0
2条评论:
I just replaced my old notifier with a new one after 2 years because the analog part will not longer keep time. This happened on both the new and older watch when the charge in the battery completely drained. Even after a full charge, everything works fine except for the analog hands Pulled the crown out then pushed it back in several times to avail. Any other ideas? The battery can't be dead - it brand new!!
完成的
The analog watch battery found inside the watch only lasts a couple years and will need replaced.
完成的
添加一条评论
添加你的答案
Dominic Coffey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 1,846
