跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
208 个问题 查看全部
How do you detach the NTrig board off of the screen/digitizer?
I've removed the (cracked) screen from my Surface Pro 4 and hope to replace it with a new screen I bought on eBay. Unfortunately, the new screen doesn't seem to have an NTrig board. Is it possible to remove that board off of the screen? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
8条评论
Does anyone know where to possibly get a new one of these NTrig daughterboards for the 4 Pro? I made the foolish mistake of throwing out the broken screen before checking to see if the replacement had one as well (have to stop assuming that parts stuck together mean they come that way), and now am SOL. I have searched on eBay and various parts vendors, and no one seems to have one. Thanks in advance!
完成的
Hi Andrew, I have just replaced my screen only to find that was not the problem with my Pro 4. What this means is I can only sell the parts of my Pro 4 now so I have a N Trig board if you still need it. Add a comment if you are interested and we'll work out some way to get in touch.
完成的
Paul, if you still have the N Trig board I may be interested in buying it from you. Email me at svcguy%sbcglobal*net.
完成的
Hi Andy, yes I still have the NTrig board. I think your email in your message got corrupted so I can't email you.
完成的
Just replace the % with @ and the * with .
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
Turns out the NTrig board is--you guessed it--GLUED to the back of the screen.
Removing it took three steps:
  1. Use the Spudger tool to pop off the connectors holding the two ribbon cables
  2. Gently pull out the ribbon cables using tweezers
  3. Slowly and gently slide one of ifixit's blue pics under the NTrig board
The board should have completely come off. You should be able to use the exist glue or 3M Double-Sided Adhesive Tape to re-attach the board onto the replacement screen.
NOTE: Re-attaching the ribbon cables to the NTrig board is very easy to mess up. My initial attempt resulted in the touchscreen not working. Reseating the ribbon cables on the NTrig board fixed the issue.
So be sure to test out touch functionality on the new display (by connecting the two ribbon cables on the screen to the motherboard's cables) before gluing it back on the chassis.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,955
