跳转到主内容
Released in January 2010, model number is 1201N-CHT-SI01HP.
3 个问题 查看全部
My touchpad is not working. What could be wrong?
Hello
My touchpad is not working. I do not know what could be the issue?
Does any one has a possible fix for this issue!
Thank you,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
<Fn> + <F3> on and off your Touchpad
完成的
添加一条评论
2个答案
已选择的解决方案
Hello Mohamed,
Please check under the device manager and see if the drivers are recognized. You can access the device manager by right click the Windows Icon and click device manager. If the drivers are not installed, please go the following link.
http://support.asus.com/download/options...
In the link just download the touch pad drivers and install it.
Another solution can be to check if the touch pad is connected to the right socket by disassembling the laptop.
这个答案有帮助吗?
得分 1
添加一条评论
you can press the function key if it didn't work you can plug an external mouse and reinstall the driver in case you don't know how to do this you first need to delete the current driver to do this right click on windows logo press device manager click mouse and other pointing devices delete the driver but be careful don't delete the driver of your external mouse then download the mouse driver you want from here https://www.asus.com/Notebooks/Eee_PC_12...
and i think this will fix any problem you have
please tell me if this work and tell me if it doesn't
thanks,
这个答案有帮助吗?
得分 -1
1条评论:
by the way this is an old and slow machine so you can expect errors
完成的
添加一条评论
添加你的答案
Mohamed Al Mardhouf Al Saadi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 843
