跳转到主内容
加入维修社区 - 创建账户
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Display backlight doesn't work
Hi, I have a Powerbook G4 A1107 (the low res 17" model) with a display backlight that doesn't work. I'm figuring it is either the CCFL or the Inverter. Is there any way to tell short of, a) purchasing a $100 inverter board and plugging it in, or b) cracking open the Display to see if the bulb is burnt?
The computer has had no other issues, there was no prior flickering before the backlight died, the cables seem in good condition and have good connections, and the display is visible when a lamp or flashlight is placed behind it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
the display is visible with another light source behind. It also works fine with external displays through both the DVI and S Video ports.
完成的
添加一条评论
1个答案
已选择的解决方案
Whiles it's booted up hold a flashlight at an angle to the screen and see if you can see the desktop. Also hook up to an external monitor to test the video chip and let us know.
这个答案有帮助吗?
得分 2
1条评论:
good answer +
完成的
添加一条评论
添加你的答案
gabemasiulis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 901
