跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
2006 Intel iMac wouldn't power on
My 2006 iMac was dead since I had long trip back. I unplugged the machine before I left. Now nothing happened when the machine plugged and press the button (no sound just black screen). It worked fine before I left.
I tried to take apart the machine and all look fine inside. I replaced the logic board battery and still same. But I found once I put on the plug, it has "da da da" sound continually from behind the logic board. It means any part broken?
Thanks for help to save my old Mac.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Three beeps is a RAM issue. Reseat the RAM and tell us what it does.
iMac Intel 17" RAM Replacement
这个答案有帮助吗?
得分 2
添加一条评论
Just throwing my two cents in here. Almost every time I see one of these machines in a store its because of a failed/failing power supply. After you've tried what Mayer has suggested, I agree with Vincent that it is indeed a power supply issue.
这个答案有帮助吗?
得分 2
添加一条评论
Hi Michael !
I would 1st suggest you to try unplugging the machine, holding the power button for 10s then plugging it back it.
I had the same problem with the same mac model. I ended up replacing the power supply unit (iFixit sells that part) and it now works well. Couldn't tell if your computer has the same problem but I'm glad that it fixed mine.
Hope this helps !
iMac G5/Intel Power Supply图片
产品
$49.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Chou 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 126
