跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Can you install 64GB of RAM on the iMac 27", Late 2013?
i know a girl online using a mac book pro that was able to *double* her macbook's max capacity GB of RAM because there was new ram out with double the GB capacity (than existed when her model of the macbook was built).
so i was wondering if the same is true for the iMac...
thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your systems specs: iMac 27"3.2 GHz i5 (Late 2013)
完成的
添加一条评论
2个答案
已选择的解决方案
To start with you have four memory slots which are broken into Banks (0 & 1). Ideally, you want to use a matched pair within a given bank.
So when you bought your iMac it came with two 4 GB modules (8 GB total RAM). You can see this by going to the About This Mac and tab over to the Memory tab.
You could add in a second bank of RAM of two 4 GB modules which would get you to 16 total RAM which for most people is more than enough. But, you could also go all the way to 32 GB if you needed to!
Here's the Apple T/N on what is possible and needed: iMac: Memory specifications and upgrades.
Hopefully that gives you a framework on what is possible. Don't forget its not just the RAM you need to review when you get to these larger sizes often you need to be running the newest OS and make sure the given App or Apps can support it.
Lastly, don't forget your drive storage having lots of RAM in a system won't help much if the drive is slow or does not have much free space!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Since 16GB modules where not on the market when the computer came out it is difficult to say since it depends on the CPU and the chipset but also how the memory module is build up. I think in this case the best thing is if you have a dealer who you could talk to and say if the memory works in my iMac i will buy it and if it does not that you can give it back.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
PRS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 4,041
