跳转到主内容
Panasonic's phone model first released in 2007 with features such as voice mail, caller ID, call waiting, call transfer and call hold. Model number: KX-TG6021M
6 个问题 查看全部
Why is my signal so bad?
When I'm a certain distance away from the charging base, my call sometimes drops.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi,
Sometimes bad signals can be cause by interferences in your home. To fix this issue you can make sure that your charging base is placed at a higher point in your home to insure less resistance for the signal. Also you can check your antenna to make sure it is working correctly and if not refer to the replacement guide to replace it.
这个答案有帮助吗?
得分 1
添加一条评论
You may need to get closer to the charging base. Also, make sure walls or other objects are not impeding the signal from the phone to the charging base.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
You Zhou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 111
