跳转到主内容
加入维修社区 - 创建账户
MacBookPro won't restart after RAM upgrade.
I have a late 2011 MacbookPro. I upgraded the RAM from 4GB to 16GB Corsair today, but the computer would not restart. It would get to the Apple logo, then freeze. Whenever I run the diagnostic test on either one or both of the new RAM cards, they pass. However, I can't seem to load the operating system (even in safe mode) with the 16GB installed.
I just re-installed one original 2GB card and one 8GB card together and the computer started without a problem, even though the cards are from different manufacturers and of different capacities. Yet, using two 8GB, it freezes.
Thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
how much ram does it show when you run it with 2 and 8 gb
I hazard a guess that 8gb sticks may not work in the machine ...
or maybe one of your 8gb sticks is faulty
完成的
I installed 2 8Gb RAM sticks in my late 2011 MBP and it works like charm @Spikey2
完成的
添加一条评论
1个答案
最有帮助的答案
Your MBP should be able to accept two 8gb sticks of ram but it sounds like either one or both of your new sticks is bad or, more likely, that the ram you purchased is not compatible with your laptop's motherboard. Just because it's the correct version of DDR does not automatically mean it will work in your computer. There are other factors like speed and latency, buffered vs nonbuffered, etc. My advice is to order your ram directly from the manufacturer and have them confirm beforehand that it's the right spec for your computer. In the meantime, just to be sure that the new ram is the problem, swap the original ram back in and see if the computer boots
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Not Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 180
