only has black lit up screen
I'm working on a sony 46" Bravia S Series lcd tv, when moved, something inside the tv raddled. Not quite sure what that is.
When turned on all it does is light up, but the screen is nothing but black. I tried to press the menu button, and change the inputs, nothing made any changes to the constant lit up black screen.
Going to attempt to disassemble tv to find source of rattling noise.
Any idea's of what might be causing the issues with the tv?
*back panel removed, picture of the components underneath.
Hi, Take the back off first (make sure that the TV is unplugged from the power) and see if anything obvious has either broken etc. or is loose.
What is the model number of the TV?
由 jayeff 完成的
model:KDL-46S504
I already took the back off, and i don't see any broken, rattling pieces. i think it's on the front half of the tv.. looking for disassembling tutorial, don't really want to just wing it, but from the looks of it, i can if i have to.
由 gagebowser55 完成的
posted picture of inside tv after back panel was removed.
由 gagebowser55 完成的
Hi, On your picture, looking at the top has a flex cable come out from the connector (TP is written on board at left of connector looking at your pic) or did you take it out?
TP to me means test point.,( but I may be totally wrong about that) also it appears that there is nothing plugged into the LCD connector?
由 jayeff 完成的
oh my lord, my bad. that's actually a picture of an rca viking pro tablet, i just changed the photo... my mistake.
由 gagebowser55 完成的
显示更多的1条评论
