跳转到主内容
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Android has stopped, won't reinitiate
Yesterday my phone was working. But this morning when I restarted it after turning it off for the night when I went to bed, I can't make or receive calls or access any of the apps, the phone giving me the message "Process Android.process.acore has stopped" when I tried. Tried restarting it numerous times all with the same result. Do I need to do a master reset, or is there some other way of fixing the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Yes you will need to perform a hard reset. Sometimes clearing the cache will help but it sounds like the android os crashed.
Turn off the device.
Press and hold down the Volume up and Power keys at the same.
When the Alcatel startup screen appears, release the Power key.
When the Android system recovery screen appears, release the Volume up key.
Use the Volume up/down key to highlight wipe data/factory reset.
Press the Power key to select.
Press the Volume down key to select "Yes -- delete all user data".
Press the Power key to select Reboot system now.
这个答案有帮助吗?
得分 0
添加一条评论
followed the steps above and no effect..
这个答案有帮助吗?
得分 0
添加一条评论
android has bin stoped
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Don Brynelsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 300
