跳转到主内容
加入维修社区 - 创建账户
The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
Why don't my daytime running lights work
My daytime running lights on my 2003 Toyota rav4 stopped working my headlights only work when I put them on high beem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
i would check your fuses, and then if all fuses are good try a new bulb.
完成的
添加一条评论
1个答案
已选择的解决方案
Jose,
First thing. Daytime runners are to be on when the headlights are off. Now the RAV 4 may possibly be setup to "add" them with the high beams, which may be why your seeing them.
Like the first answer said. Check the fuses, inside car and under the hood. They run through the head light switch, which could be problem.
I'll look into it and see if there is anything to be found.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jose valles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,333
