跳转到主内容
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 个问题 查看全部
Why wont my Laptop start up, even after changing the 2 Batteries
I am having trouble rebooting my laptop (1.67Ghz,120HD,2Gb RAM,MacOs 10.4.9 or 10.4.11)
Have taken RAM out, swapped slots, done the PMU reset, holdiing power key for 5-10 sec, ect. All with no luck.
Came back from holidays & it wouldnt get past the DVD check.
There is NO Vid display at all, not even a flicker.
the DVD seems be trying to eject maybe a DVD.
The batt was playing up before I left on holidays, charged to 99% full, take out power AC, at 75% would want to shut down cuz of low batt even though screen display said 75%.
Is there a button to push on the Board like on a desktop G4 logic board
Also had a different sound insted of the normal chime. like a "dong" sound, then the light on the front open switch flickered fast & brightly for about 5 secs.
What is the different sound mean foloowed by the rapid flickers of the light.???
Have swapped new main batt. & new PRAM batt.
Much appreciated for your advice please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Hi rj713....Have done all as you mentioned
There is still no response from the laptop .... there was a "funny" long chime sound, after I did the FORCE SHUTDOWN. I think its the "death sound".
It seems to get stuck on trying to evict a DVD, even though there is no DVD in the driver.
完成的
添加一条评论
1个答案
已选择的解决方案
Try resetting your PMU--link provided. Link also provided to reset your PRAM.
http://support.apple.com/kb/HT1431
http://support.apple.com/kb/HT1379
这个答案有帮助吗?
得分 1
1条评论:
Try disconnecting the DVD drive and see if you have the same problem.
完成的
添加一条评论
添加你的答案
harry allcock 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 1,146
