跳转到主内容
The Toshiba Enore WT8-A is a touchscreen tablet running Windows 8.1.
6 个问题 查看全部
My battery dies very quickly.
I charge my device all night but when I use it the next day, it lasts a maximum 2 hours.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You will most likely need to replace the battery. The factory battery may become depleted very quickly and therefore may required to be replaced to achieve longer-lasting battery life.
这个答案有帮助吗?
得分 0
添加一条评论
As Zachary said before me, you most likely might be considering a replacement battery.
However, recently I've been using an old Samsung S3 phone which seemed to only like to maintain a 2-3 hour charge regardless of the fact I can leave it plugged in for 10 hours or 10 days. A simple walk to the store less then 10 minutes away, with a 40 minute round trip (shopping) would result in the phone being well under 20%.
The last two weeks however It's managed to maintain a charge (staying over 20%) for over 10 hours or longer.
What did I do you might ask?
Bought a new charging cable. One that said 'data and charging' on the packaging. (I had been using a lighter weight cable intended for a smart watch)
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zachary Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 217
