跳转到主内容
The Toshiba Enore WT8-A is a touchscreen tablet running Windows 8.1.
6 个问题 查看全部
When I plug in earphones, why is there no sound?
Whenever I plus in earphones, no sound comes out. I try to play videos or music and hear nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
First off, ensure that the headphones work by plugging them into another device. If the headphones do work, the audio jack may need to be cleared of any dust or particles that entered the opening. Try looking into the opening to see if there are any objects blocking the connection. If it is still unsuccessful, you may need to replace the audio jack using the replacement guide.
这个答案有帮助吗?
得分 0
添加一条评论
Alternatively you can make sure bluetooth is disabled and not trying to 'stream' your sound to another device. I've come across this recently.
You could also try a reboot of your device to ensure the system is fresh.
Are you sure the volume is turned up?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zachary Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 138
