跳转到主内容
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 个问题 查看全部
问题已关闭
Half screen Frozen on right side display
When using phone, the right side of the screen becomes frozen and will not change.
Have to turn off and let set for several min. before it restores to full screen. If I turn
off the phone during the freeze, the right side goes all "fuzzy" like when you change
the TV to a dead channel.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
please tell the solution
完成的
添加一条评论
2个答案
I got it fixed. It turned out to be the faulty battery that caused it. Strange but true. I replaced my battery with Duracell battery for Note 4 and the problem disappeared ever since. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
just change it & display will be ok
这个答案有帮助吗?
得分 0
1条评论:
“change it" what?
you indicated a pin apparently?
can you please elaborate?
thank you @maikei
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 2,511
