跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Does a replacement home button have to have the ribbon cable?
I'm trying to install a white home button on my iPhone 4 and on your instructions I see that the button is connected to the ribbon cable. Can the black button be replaced with a new white button on the original ribbon cable or does the new button have to come with a ribbon cable attached?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
When I took apart the phone I didn't see a way to swap just the home button. Although I didn't look incredibly hard to find a way so it might be possible. It just didn't look easy enough for us to sell the part and encourage the repair. I can tell you that the electronic switch for the button is housed in the ribbon cable instead of on the logic board as with previous models.
这个答案有帮助吗?
得分 0
添加一条评论
The new button does not require a new ribbon. The electronic switch is easily scrapped off the old and placed onto the new.
这个答案有帮助吗?
得分 0
添加一条评论
It does scrape off (or, more precisely, peel off) from the back of the plastic button — there's actually a really nice grooved recess into which the Home button switch "decal" sits just perfectly. Really the only catch with replacing this piece is properly seating the other end of the Home button switch ribbon cable — the tip of its "tail" back into its tiny harness. It wouldn't be such an issue except that you pretty much have to reassemble the entire phone, with layer upon layer of electronics components covering up this junction, just to be able to turn on the phone and test to see if the ribbon cable has been plugged in to the harness far enough, or otherwise correctly. And if you didn't, you need to disassemble the whole thing all over again. Why Apple couldn't have put a nice, neat little "plug" on the end of this ribbon cable to make a a neat little socket connection (like the rest of the connections in this phone) is beyond me.
I have had similar travails seating the keyboard ribbon cable on my MacBook Pro into its much longer harness, but that's a story for another day…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrett Nichols 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 774
