跳转到主内容
加入维修社区 - 创建账户
The Polaroid Cube is a splash-resistant, shockproof, and mountable camera that takes 6 megapixel pictures and shoots videos in 720p or 1080p HD.
Why isn't my computer detecting the Cube?
My computer is not recognizing my Cube when I plug it in with the USB.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Make sure there is an SD card installed in your Cube. The Cube will not work or be able to be detected without an SD card. Also make sure that your SD card is at least Class 10. Lower Class cards will cause performance issues. Check out the Troubleshooting Page for more information pertaining to your device.
这个答案有帮助吗?
得分 4
添加一条评论
FYI, Make sure you are using a USB Data Cable and not just a USB Charging cable.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! That did the trick!
完成的
添加一条评论
添加你的答案
heath lamkin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 7,820
