跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Why SSD's is not working?
Hello everyone, I got MacBook Pro 9,1 and I want to upgrade it from HDD to SSD.
I tried Samsung EVO 850 - No luck, only working through USB
Now I got OCZ TR150 - Same problem
But HDD is working fine! I heard about problems wit SMC and BootROM versions, mine is the last versions Boot ROM:MBP91.00D3.B0D / SMC: 2.1f175
Some people in the web tells that changing the sata cable will do the magic, but what the difference between stock sata cable and the other one? (From iFixit)
Sorry 4 my English lol, I'm Russian
Update (10/25/2016)
Non-workin cable inside
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well to start off your English is better than my Russian ;-}
Yes, you need a new HD SATA cable. While your HD is able to use the current cable your new SSD just can't. It all comes down to speed!
The Apple drive you currently have is a SATA II (3.0 Gb/s) drive, your new Samsung SSD drive is SATA III (6.0 Gb/s). The SATA cable your system came with is only rated for SATA II which is why you need to replace it. Unlike desktop systems laptop cables are finicky!
You need to use the newest version of the cable: MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0084
Удачи!
Replace a damaged cable connecting the hard drive to the logic board in your laptop.图片
产品
$19.99
这个答案有帮助吗?
得分 2
4条评论:
Thanks Dan! That means I need to find a part with 923-0084 number, right? (I just want to try find it in the local stores in Russia)
完成的
it woud be nice if u tell me what digits gotta be on the cable exactly, thx
完成的
Numbers & Numbers!
Apple P/N's are different than the manufacture number. You should go by the Apple P/N number. For reference: Hard Drive Data Cable for the MacBook Pro 15" Unibody - 923-0084. The 923-0084-01 is the newer (better) version manufactures number.
完成的
Much love from Russia, Dan! Your support is helped me alot! :)
完成的
添加一条评论
添加你的答案
Pavel Mamontov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 213
