跳转到主内容
由富士通所制造的笔记本电脑。
74 个问题 查看全部
screen turn on and off when I touch the laptop lifebook s751
screen turning on and off when i touch the laptop mostly on the body, everything is working ok even when i touch the screen ,, so i dont think so its about screen.. i tried to open it up but all wires or sockets where in the right place.. so i wonder what it might be.. should i just change the main board?
what you think guys?
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
first u need to check the connector cable from monitor to the board it's likely the issue here , maybe not connected well from both side u better check or corrupted need a replacement.
这个答案有帮助吗?
得分 0
1条评论:
i checked everything, i disassembled down to the main board, everything looks very ok. ports are solid, but when i push some where around to the CPU fan area picture will gone, and i have to shout down and turn on again. i tested the main board alone to be sure nothing is shorting between sink and main board, but still same result..
any idea?
Thanks
完成的
添加一条评论
添加你的答案
frankdez 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 7
总计 87
