跳转到主内容
This is a 2006 HP model number NC6120 laptop. Enclosed within a black case, it contains a 1.73 GHz Intel Pentium Processor, 512MB of DDR RAM, and a 60 GB hardrive.
2 个问题 查看全部
Can I upgrade the cpu?
Can I replace the Pentium m with a core duo or higher? If I can then let me know and show he how to upgrade. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My laptop have socket 479 mPGA with i915GMS/i910 chipset. can i upgrade it to any dual core processor that could work as good as a core 2 duo processor? And what kind of ram can i put inside, i want to upgrade to 2gb of ram but dont know what kind to get
完成的
添加一条评论
3个答案
已选择的解决方案
Hi,
Here is a link to the type of memory used in your laptop.
http://www.parts-quick.com/336579-001.ht...
Here is a link to the service manual for your laptop. Scroll to section 6-34, at the top of the page it details the memory options available for your laptop. As it only mentions 256MB, 512MB and 1024MB (1GB) memory modules as replacement parts you would assume, as there is only one slot that 1GB would be the maximum that it can handle.
You could try inserting a 2GB module using the same specifications, (PC2700 DDR SDRAM 200 pin 2.5V 333MHz SODIMM Memory) and see if it will work. You can only try.
http://h20566.www2.hp.com/hpsc/doc/publi...
The manual also shows the replacement CPU types available. The CPU is held in its' socket by a screw. You would also have to check that the BIOS would support the new CPU if you changed the type.
这个答案有帮助吗?
得分 2
4条评论:
Hmmmmm, if the ram for some reason don't work, will it do any damage to the motherboard or fry it? I read that from some forms and I really don't wanna fry the motherboard.
完成的
If you get the exact same specification RAM , except that it is 2GB of course, then it will either work or it will not work. It should not affect your motherboard. Make sure that you follow the normal procedure when replacing RAM. Switch off the laptop, remove the power adapter, and remove the battery pack before you remove the old RAM and reinstall it after you have inserted the new RAM. You will know if it doesn't work the laptop will give error beeps or not start.
完成的
About the manual, It don't say much about upgrading the cpu, or any other compatible cpu.
完成的
On p.6-30 in the manual it shows all the compatible replacement cpus for the laptop with their part numbers. Search online using only the number and you will find the cpu,(I said all the replacement cpu available in my first answer, not whether they are upgraded or not) On p.6-31 it shows how to remove the cpu
完成的
添加一条评论
First you have to see if your laptop has a socketed or soldered CPU. You can only upgrade laptop CPUs if they are in a socket and can be removed. If so, either way you wouldn't be able to use a Core Duo in that system, only the ones listed on this Wikipedia page.
这个答案有帮助吗?
得分 0
2条评论:
But most of laptop cpu aren't soldered to the motherboard, are they?
完成的
Typically they are soldered in order to reduce size, and to create CPUs with laptops in mind that reduce heat and energy usage. Most if not all modern laptops have soldered CPUs, but yours very well might be socketed because it is far from modern.
完成的
添加一条评论
depends son ur board some boards can't stand i3 or i5 so check the specification of the board first if it's no problem just YouTube it and u will find it easy .
这个答案有帮助吗?
得分 -1
1条评论:
But it is pretty much in tact, no upgrade, stock motherboard, can I upgrade?
完成的
添加一条评论
添加你的答案
quochuyvn1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 2,581
