跳转到主内容
加入维修社区 - 创建账户
Frame slightly bent, CD's will not eject unless pressure is applied
The frame around the optical drive is slightly bent, not in a way you would normally notice. You have to look level across the keyboard to see a slight depression to the right of the trackpad above the CD drive (cd drive slot ever so slightly bent as well).
CD/DVDs will not eject unless pressure is applied to bend/straiten the frame slightly. With just with hand pressure around the optical drive area while someone else pushes the eject button.
Is it possible to bend, or manipulate the metal back to a suitable form to allow the CD drive to function again? (without making it worse, not fit back together or just have the metal go back into its current state once reassembled). If so, best way to do it?
Just looking for a way to make it functional again, when so close to working correctly on its own.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
the display frame is bent in the middle too, with a gap at both ends showing when the display is closed, .........another question i guess.......
完成的
添加一条评论
3个答案
已选择的解决方案
Popsicle stick
to twist/press into shape. You may have to dismantle the upper case to press on the back.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 2
3条评论:
fantastic idea, i will try tomorrow, I had thought of something similar to this, I just was not sure how the metal would respond and to what kind of tool. (i will definitely click on answered question once i give it a go and post any relavent info it if doesn't end up working and i try something else) Thank you.
完成的
good answer +
完成的
seems to work! I was only able to get to it today, and worked on it carefully for a while, i used a balsa type wood shim with a wider surface area and even thou there may be some additional manipulation needed to make it perfect and to ensure the problem won't return with continued use of the computer. The drive can now eject optical discs and it didn't take very long at all.Thank you.
完成的
添加一条评论
super drive ejects "hard"
这个答案有帮助吗?
得分 2
1条评论:
another good answer +
完成的
添加一条评论
I took my MBP 15" A1226 to the Apple Store where I live to investigate the same problem. The genius bar guys took one of the black stick spudger thingys and wedged/twisted it back to shape. Looks normal now. However, I think the drive was already bad because it was already having problems recognizing burned CDs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 4,119
