跳转到主内容
加入维修社区 - 创建账户
亚马逊于 2013 年 11 月发布的高端平板电脑系列 8.9 英寸版本。
Restarting continously over and over to Logo
I downloaded a new app and my HDX turned itself off and started a cycle of restarting that will not stop. Did a number of factory resets, no change. It restarts only to the colored logo and shuts off and restarts over and over. Amazon said that it needs to be replaced. Can it be repaired?
Also I have left it on the charger overnight before the last factory reset and it makes no difference.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
This started on mine tonight after support said to Reset to Factory Defaults. I loved my HDX!
由完成的
I was reading a book when this happened to me, page just locked up, did 40 hold thing then HDX in logo boot up loop, spend hours on chat with Amazon, finally they told me to replace it. I did but if I can fix my HDX I will and like you I really love it. Requested HD from here, hope it has OS then I will try and fix mine.
由完成的
添加一条评论
2个答案
Hi!
You're gonna have to boot to recovery mode in case of a boot loop.
While it's off, hold the power key and volume up.
You will be prompted to Recovery mode. Use volume to scroll and power to select.
Try wiping cache partition. Then reboot.
If that doesn't work, try the same steps, but instead factory reset.
If that doesn't work, then you should definitely get a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem, so I prised it apart expecting to remove/renew the battery. Inside I discovered the works were retained by 8 tiny steel screws. To keep these safe I decided to store them, on a strong magnet. Starting at the bottom right corner as I brought the magnet to the screw the Kindle immediately stopped malfunctioning. I tested all operations and everyone worked properly and without the sluggishness which had developed over the previous year!! Try this method without prising apart. Start at 4 ( of the clock) and move anti-clockwise. Share the result!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darrel Plimpton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 23
总计 12,142
