跳转到主内容
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
Why is does my MacBook randomly go to sleep when moved?
whenever I move my macbook in any way, my computer goes to sleep and the only way I know how to turn it back on is by moving the macbook around again. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is this happening everywhere or only in a certain location? The Macbook will go to sleep if the side of the side of the keyboard comes in contact with a magnet (this is how it knows when to sleep when you shut the screen).
Make sure there is nothing on your desk which could trigger this, and try using it elsewhere to see if it still happens.
这个答案有帮助吗?
得分 2
2条评论:
I've tried it somewhere else, no difference.
完成的
That's strange. If it is definitely not caused by a magnet, it could be an issue with the SMC_lid circuit on the logic board, responsible for putting it to sleep? I haven't seen this suddenly activate without cause though. Older models have a sudden motion sensor which can sometimes cause issues, but the newer Macbook Airs do not have this feature.
Backup the data and reinstall a fresh OS, see if it is still having the same issue. Remove the bottom panel and check for liquid damage as well.
完成的
添加一条评论
添加你的答案
Mannix Thomson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 943
