跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 screen taken off, cant connect to to iTunes anymore.
Screen was completely destroyed nothing shows, nothing works, but it connected to itunes. i tried to recover, i deleted the iOS and everything and then it showed me iTunes errors 3194, 4005, 4014. What to do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I removed the screen completely, can i still connect to computer without screen?
完成的
Assuming that everything else is in working order, you should have no problem plugging in an iPhone with no screen to iTunes.
完成的
添加一条评论
2个答案
已选择的解决方案
I tried an iPhone 6 without screen plugged into charger and it just loops with the charging sound meaning it crashes shortly after boot and keeps looping.
So no you can't boot the phone successfully without a screen on iPhone 6.
这个答案有帮助吗?
得分 2
添加一条评论
Error 4005 or 4014 is a hint that there is a problem with the NAND Flash memory.
Maybe there is a cold solder from the hard drop event, so that you cannot restore it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Proktors 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 72
