跳转到主内容
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
My phone will not turn on
My phone will not turn on or charge. I was talking on skype and the phone turned itself off several times and came on automatically. It then froze and I took the battery out and turned it back on and it was working fine. I then plugged it back in again and it turned off almost straight away and since then I have not been able to turn it back on. I also noticed that the phone was getting quite warm. During the last week the phone has also been very slow.
There has been no water damage or falls.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Might be a good idea to try another battery? A faulty battery can cause issues like the phone shutting off and turning itself on again right after because the battery voltage (also battery not being read correctly) was too low for the phone to stay on properly.
完成的
添加一条评论
1个答案
Sounds like a battery or charger issue. Try another charger if you have one (cord and brick) and then maybe look at a new battery if that fails.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
theresiaskagerfalt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 71
