跳转到主内容
加入维修社区 - 创建账户
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
12:00 AM keeps flickering after battery drained and replaced
My alarm was showing low battery and it went dead for a couple of days. After I have replaced the batteries (tried many of them) it came back to life (radio works fine) but neither the clock or the alarm work. Whenever I plug it into the wall it starts flickering 12:00 AM and doesn't give me the options to set the time. Can anyone please help?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Take the battery out to set time & date, put it back in after everything is set.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Try the following and see if it helps.
1. Remove the AC cord from the wall outlet.
2. Remove the battery from the clock/radio.
3. Press and hold the Time Zone button for approximately 15 seconds then release.
4. Connect the AC cord to the wall outlet and turn on.
5. Insert the battery back into the battery compartment. (ensure that the +ve mark on the battery is facing up)
6. Press the Radio button to remove the low battery symbol being displayed.
Hopefully you now can set the time etc.
这个答案有帮助吗?
得分 2
3条评论:
Thank you so much for your answer but it didn't work :((((
It's still flickering and I am not able to set the time.
完成的
Me too it's still flickering
完成的
Leave clock plugged into wall and remove the battery, set time and date, then reinsert battery.
完成的
添加一条评论
添加你的答案
salma shamel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 3,968
