跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
Pentalobe screw keeps spinning
One of the two pentalobe screws on my iPhone is just spinning around when I try to unscrew it. This is an urgent problem as my battery and lightning port are in the way out and I would like to replace them before anything else goes wrong. If anyone can answer this problem. One solution i have seen of is to drill out the screw with a 1/16 drill bit. Ideally I would preferred not to do that as I may cause serious damage to the phone.
Help plz
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Please don't drill out your phone.
Lift up on the screen just a bit with a suction cup or pry the screen upwards just a tad, a couple mm will do, then the screw should grab. Chances are the part of the screen that the screw goes into is broken off, so you have to get some leverage on it.
这个答案有帮助吗?
得分 4
4条评论:
Hi,
I had just the same problem, apple under dimension the inside "nut" on the pentalobe screw. Maybe i gave it 200 gram of force and than i broke the nut.
After some hours of hardcore thinking, my woman went in to my office with a fridge magnet and tell me to try it out. I taught the frame was magnetic and the fridge magnet was to weak, but I gave it a try.
It worked...
完成的
where do i place the magnet
完成的
on the magnet or screen
完成的
My issue is that the screw head is stripped will this method work for that?
完成的
添加一条评论
Prise the screen up with a screen opening tool (sucker) whilst unscrewing at the same time. It sometimes then bites and unscrews.
这个答案有帮助吗?
得分 2
2条评论:
Created an account just to thank you. I appreciate it.
完成的
It worked !! Thanks
完成的
添加一条评论
添加你的答案
Truant Toucan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 6,547
