跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
82 个问题 查看全部
Original screen adhesive, how to use?
Hello, I got this screen adhesive
witch I believe needs to be heated to stick to LCD and frame, but I already tried to do like 4 phones and it doesnt hold. Im trying to heat it on 85-90C for about a minute, do I need more heat or hold it on there for longer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I use heatgun, but carefully. I have a heatgun (HG) with small nossle. First clean the edges of frame with isoproponol, then put the adhessive sheet with the glue side down. Use the HG to warm carefully the corners and use a tip of a tweezers to press so the adhesive stick. You can see it when it stick to the fram, it become more transperent. Then do the rest of it.
Then take of the plastic "cover", install the screen and do the same heating on the screen it self. On the sides, make surre you heat only the 1 mm edge. I use my fingers with a paper or something to press and swipe the heated area to make sure the screen is pressed down until adhesive is holding it.
Heat plate can also be used. There are many othe similar questions in the forum descriving the same.
这个答案有帮助吗?
得分 0
添加一条评论
Hi, this blog tell you the differences between original screen adhesives and non original ones, also tells the way of how to use the original screen adhesive, maybe you can have a check http://www.etradesupply.com/blog/what-yo...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eimantas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 701
