跳转到主内容
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
20 个问题 查看全部
Start up shutting off when MSI logo shows.
When I turn on my laptop it gets to the MSI logo then shuts off. I can get to BIOS by hitting enter while booting up. I don't know where to go from there.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Power it on and hit delete to go into bios mode and disable fast boot.
这个答案有帮助吗?
得分 1
1条评论:
Disabling Fast Boot worked for me.
完成的
添加一条评论
Susan,
Having the computer shut down at the manufacturer's logo or during P.O.S.T., is a prime symptom of overheating.
The first thing you should do is get a can of compressed air and blow out the vents at the side of the laptop.
The second thing you should do is confirm that the fan inside (if there is a fan) is actually rotating to circulate air away from the processor.
There are other things that COULD cause this symptom, but this is the most common for most/all laptops.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Susan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,426
