跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
727 个问题 查看全部
My port to the HDMI is broken in the Xbox
My question is I broke the inside HDMI port for TV output from my Xbox one. Is there any Alternative way to play my xbox some how? If not where can I get the parts to fix it and is there a guide on that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
Can you not just take the HDMI in pass through port and desolated it and move it to the HDMI out port to make it work for now and fix hdmi in if you even care about it.
完成的
添加一条评论
10个答案
最有帮助的答案
If you search "Xbox One HDMI Port" on eBay, they have the part on there. There are also lots of videos on YouTube showing how to replace it.
I would warn you though, if you don't have experience in soldering, you could damage the main board trying to remove the old port. If you're not comfortable with the repair, it would be worth having an experienced tech do the soldering work for you.
这个答案有帮助吗?
得分 3
1条评论:
David is right. I fix lots of them where someone has tried to fix it but didn't know how. It ends up costing them a lot more because they tear the circuits traces off the motherboard.
I get that people like to fix stuff themselves but just be realistic with your abilities and tools.
完成的
添加一条评论
If you get a hdmi to USB adapter can you not plug the hdmi cable in one of the Xbox’s usb slots?
这个答案有帮助吗?
得分 1
9条评论:
Yes I would like to know this. I am trying to find a solution to my sons hdmi issue on his 1 yr old xbox minecraft edition
完成的
Yes i would like to know trying to see if i should buy one
完成的
Anyone ever try it?
完成的
I bought one offline and it isn’t working for me at all
完成的
Any luck with this yet?
完成的
显示更多的4条评论
添加一条评论
you should be able to get the parts here on I fix it but maybe radioshack or some other eletronuics bussiness
这个答案有帮助吗?
得分 0
1条评论:
ifixit does not sell those parts, nor does RadioShack or any other brick and mortar store that I know of. It's an online only part.
完成的
添加一条评论
hdmi port replacement on xbox requires micro soldering and desoldering technique otherwise you will end up breaking the pads on logic board we have done many hdmi port replacement in our workshop for us it is easy if you live in new eland you can send it to us
这个答案有帮助吗?
得分 0
1条评论:
What is your workshop?
完成的
添加一条评论
Get it from eBay like everyone said, or if you have a pc with windows ten, you can stream it directly to the pc and plug the controller to the pc or turn it on and play without it being plugged up to the TV
这个答案有帮助吗?
得分 0
1条评论:
Please elaborate on this .... I have the same problem
完成的
添加一条评论
Yes I have the same broken hdmi slot
这个答案有帮助吗?
得分 0
添加一条评论
Can you not just take the HDMI IN pass through port and desolder it and move it to the HDMI OUT port to make it work for now and fix hdmi in if you even care about it.
这个答案有帮助吗?
得分 0
添加一条评论
i really wanted to get the Fortnite battle pass so iam sad
这个答案有帮助吗?
得分 0
添加一条评论
How can I play my Xbox one x if my HDMI is broken on my tv
这个答案有帮助吗?
得分 0
添加一条评论
connect a controller to your phone and do remote play through the xbox app
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 46
过去 30 天: 123
总计 69,403
