跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Display stops working when unplugged from charger
My 80 gig Ipod stopped working and is not under warranty. I replaced the battery, did nothing, and then replaced the logic board and started working again. As soon I unplug from charger, the screen goes blank. Plug back in, and the sceen lights up again. While plugged in, click wheel works and can scroll through menus.
I must mention, on one of the last reassembly steps when reattaching the headphone jack ribbon, the clasp that flips down to hold the ribbon in place broke off, so the ribbon is being held in place with electrical tape. Very aggrevated about that. Not sure if this contributing to the problem. Of course, when I plug in headphones when the Ipod is plugged into the charger while it's working, there's no sound.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
That problem is usually caused by a bad battery. I would check to make sure the battery is plugged in all the way and let it charge for a few hours to see if that makes a difference.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks. I'll check it out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 597
