iPhone 5's screen was black and won't turn on
Hi!
I slept yesterday with my iphone 5 beside me, and when I woke up, the screen was already black, eventually, it already turned off. I was trying to turn it on but it wasn't working. I charged it but the battery is overheating. What do you think is the problem and how I'm going to fix it. I seriously need a help please :(
kindly help me please
由 A M 完成的
Where exactly does it feel hot? Left side of phone? Right under back camera?
Have you tried another charger and cable?
If yes, either take it to a phone shop to get it looked at, tested and repaired or Try another battery first then charger port.
由 Ben 完成的
Hi Ben! Yup. It's hot right under back camera. I already tried other charger and cable. What do you mean by "Try another battery first then charger port"?
由 A M 完成的
Any other suggestions or tips? Badly needed :(
由 A M 完成的
If it's hot right under the rear camera then don't worry about the battery and charger port as this is actually a bigger issue with the power management on the logic board. This is a board level issue so I recommend taking it to a professional that does board level repairs on iPhone 5.
What I meant by trying another battery is to try a replacement battery in the phone and for charger port I meant the charging dock assembly which is basically the charging port assembly inside the phone, but those parts are most likely not at fault anyway now since you've said it heats up at that specific spot.
由 Ben 完成的
显示更多的2条评论
