Why is my phone not charging?
My phone is not charging. I have tried to plug it in multiple different outlets and checked to make sure the cable is not cut anywhere. What can I do now?
You can unplug the charger and clean the connector and if that does not work you can check to see if there is corrosion on the charger adapter or if it is loose in the phone. If this is the cause you may be in the market for a new charger. If this is not the case it could be a phone/battery error and this would require you to send it in so you can get a new device or we can fix the tiny electrical components that makes your device charge!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 112
