跳转到主内容
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Won't take keyboard input
This machine is the 2 Ghz DP version, 2005.
It will chime and boot to the internal HD.
I lost the password so can't login.
I then try with the DVD install to reset the password.
It will not take any keyboard input combination to reset NVRAM, boot off DVD---nothing.
The keyboard works because when I tried some password input it prints on screen.
I took the HD out, put it back in and on an SATA channel it did not like. It did not boot.
I changed it and it booted but this time without anything on screen...it does not seem to boot completely.
I cleaned the tip of the video card. No luck.
Any help will be appreciated.
Thanks
Update
I must also mention that I've removed RAM, battery, etc, to see if it's locked with firmware that's preventing the keyboard input at boot, but no luck. I think that's the real problem here....not responding to keyboard input during boot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
See if the "Option" key will work when booting with the DVD inserted. If so just select the DVD disk. It also sounds like you may not have connected the SATA data cable completely or have a bad cable.
这个答案有帮助吗?
得分 1
2条评论:
I have an Intel MacPro that got a lightning hit and I can not access any of the native USB ports. I installed a Sonnet Alegro USB PCI card (mine was PCI-E) and all works well now. Her's the card you may need: http://www.sonnettech.com/product/allegr...
完成的
Good answer +
完成的
添加一条评论
添加你的答案
Nesta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,628
