跳转到主内容
加入维修社区 - 创建账户
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
My screen doesn't work after digitizer replacement
I damaged my screen, but I ordered new one from eBay and I replaced it. The thing is, I damaged a microchip near the display connector (one of the squares) is there anyway to recover it back? or only with a new motherboard replacement?
http://tinypic.com/r/jhvgg8/9
I already restored device, charged it, it works nice, even shows backlight and makes sound, just no image....
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The component that is missing is a choke (90 ohm / 50mA). The fact that it's not there cuts the continuity between the drive circuit and the display, which is why everything else works except the screen. These chokes are available from major electronic suppliers and can be replaced with the proper tools and experience.
Theoretically, you could also short out the two signal paths (perpendicular to the connector, like this || ) although your device may/will suffer from EMI and cause perhaps some undesirable effects. The best option is to have this component replaced. Look for a skilled micro-solderer.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
namzz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 134
