跳转到主内容
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Why is my right bumper phantom pressing itself?
Hi, Yesterday i woke up and turned on my controller to play some black ops 3. Well next thing i know it's automatically taking me from the home side of the dashboard to the other side of the dashboard like it was stuck. So i clicked on it a few times to see if it would stop that didn't work so i opened it up and nothing is out of the ordinary. the bumper isn't broken and the button that makes the click internally is pressing normally. I am absolutely furious right now. i put it back together then threw it on the ground and the bumper poped out it.. what is the problem? besides the fact the bumper is out i can fix that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Hi i have a similar problem and when i press LT it will continue when i have my finger of of it please help
完成的
My a button does the same thing it just spams everthing
完成的
I have a left bumper problem where it's like pressing by itself and I can't fix it plz help
完成的
I hvae that problem too with my left bumper also it started like 3 days ago
完成的
添加一条评论
5个答案
最有帮助的答案
Hey Trace I just had this problem . After several youtube videos that didnt help at all, I found the solution.
I toke apart the controller and actually carefully push the housing unit of the bumper switch toward its respective button and it worked. I dont really know why but it does. I had up my pcsx2 emulator, to test the button functions in the control mapping. I kept the back of the controller attached and just took off the face. This way you can put the battery back in and while the controller is running (and with the mapping test on the emulator) open you can carefully press against the housing unit until you see that it is functioning properly. Good luck to you man hope it all works out,
这个答案有帮助吗?
得分 1
1条评论:
tell me it in english plz
完成的
添加一条评论
I have this problem too. I don’t want to destroy my controller by taking it apart. I have very little experience with things like this. I am trying to find out if it can be fixed without taking the whole controller apart.
这个答案有帮助吗?
得分 1
添加一条评论
Ok I know this is old but my controller was doing the same thing and whatever I did seemed to fix it so I’m going to post exactly what I did leading up to it working again.
I hit it (Ik lmao)
I held it down then stopped and did this a few times
I blew into the button (this is what I’m assuming worked the best)
I also pried on it for a second with my finger but I don’t think it did anything and it could’ve easily messed it up worse so I’d recommend not doing that.
This most likely won’t work for everybody but it’s definitely worth a shot if the button itself isn’t broken and it’s just “phantom pressing” itself over and over.
这个答案有帮助吗?
得分 1
添加一条评论
it might be your bumper switch
https://youtu.be/e0A6p9nSYeE
这个答案有帮助吗?
得分 0
添加一条评论
Essentially, I did a very similar thing. I smacked it against the wall a couple times and that sorted it for a little while but then it stopped working again. Also, leaving it for a day or two also seemed to work for me. I also hit the RB bumper on the wall and on my chair a few times, a little bit out of frustration and a bit out of logic. I’ve seen videos online of people fixing TVs and other various objects by hitting them so I did the same and it worked. I tried to take the controller apart but I don’t have the right screwdriver so I can’t really.
But, in conclusion, I smacked it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trace 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 117
总计 32,254
