跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Can I use iPhone 5s charger port in an iPhone se?
So my iphone se stopped charging by itself today morning so i had it open to check the plug but it seems to fine now i have my old iphone 5s so is it possible to use the 5s charger port and switch it to SE?
thanks any help will be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
已选择的解决方案
No
20charbecausesomestupidpeoplesaidso
这个答案有帮助吗?
得分 5
2条评论:
just curious what is the difference?
bcux it looks the same to me online. i dont want to open up my 5s(which is never been opened).
完成的
Different connectors
完成的
添加一条评论
No, it seems it doesnt! The connectors types are reversed comparing to 5s, and they are part from the cable band which I dont imagine how’d be “easily transfered”. I lost some hours and money because of that comment!
这个答案有帮助吗?
得分 2
1条评论:
Yeah, your right I tried swapping the port from a broken 5s I had laying around trying to fix my little sisters SE and it was a waste of time because it's exactly what you described.
完成的
添加一条评论
Actually, the charging ports are exactly the same apart from the socket where the home button connects to. The only difference is that it appears to have an extra bit of "housing" where the home button flex connection sits which can easily be transferred from the original cable anyway. I've just connected a 5S charging port to a SE and it charges perfectly!
这个答案有帮助吗?
得分 1
3条评论:
Can you use the home button and touch id Still cause I have an extra 5s part and I don’t want to buy something if I don’t have to
完成的
This is not true, the connector that goes on the logic board is different.
完成的
You are incorrect i wasted my time trying
完成的
添加一条评论
Well it worked perfectly for me so you must be doing something wrong or used too much pressure connecting it to the board.
这个答案有帮助吗?
得分 0
1条评论:
I’m gonna try out this project to see if I can get my Touch ID working on my old se using an iCloud locked 5s, I’ll let you know if it works or doesn’t work. And if it doesn’t then i guess I’ll have to resort to using the SE and a squared off iPod touch if I have to.
完成的
添加一条评论
添加你的答案
Poojan Joshi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 17,392
