跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 no sound
i have an iPhone 6 and one day i opened it to replace the battery after i start it up
i noticed that the iPhone has no sound at all when i open youtube app shows an error Playback Error , snapchat won't load videos instagram too and i pluged in the headphones and the sound work perfect when i connect with a bluetooth speaker the sound work perfect too. i tried to change the speaker change the chargning port but no luck. i have more .. when the phone is on and i plug the headphones don't show me the volume HEADPHONES but Ringer so i have to reboot my device to activate the headphone mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
My guess is you broke the power/volume flex when removing the battery. Did you have to use pry tools to change the battery or did you use the pull tabs?
这个答案有帮助吗?
得分 1
2条评论:
no i know how to remove the battery just by pulling out the glue under it but it's not the problem there i have replacet the motherboard (my motherboard) into another iphone 6 (works very well) but my motherboard still do not support sound in any speakers
完成的
Good. I'd still try a new volume flex. Its a good starting point.
完成的
添加一条评论
Hello. In my opinion it's not volume flex damaged. But ive got questions for You :
1) Does your phone getting lag when trying to rec a video, or trying to watch any video with sound on YT
2) Does Phone lag while some1 calling you, when you have sounds turn on , and does he works properly when you have sounds off ?
When phone works properly on headphones You could have damaged sound IC, it's very expensive in repair, and very dangerous, beacause its "under" screen connections on Mainboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adrian Zymeri 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 6
总计 262
