跳转到主内容
加入维修社区 - 创建账户
Part of the Acer Gemstone series, the Acer Aspire 7736Z-4809 offers a larger display than most laptops. Repair of this device is similar to other models in the 7736 series.
Why isn't my USB port working?
I always leave in the USB plug for my wireless mouse in the laptop, and the mouse has always been detected. The other day I turned on my laptop and it refused to detect the mouse. I tried changing the batteries in the mouse but that was not the Issue. I also tried removing and reinserting the USB in the same port. It was only when I tried the one of the USB ports on the left side of the laptop that it worked (I always use the one on the right). That's when I figured the USB port on the right is broken. I'm always using removable devices and would like all 4 ports working. How can I get this fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Seeing how your mouse worked on all but one of the ports, it's possible the USB driver is corrupted. Go to the Device Manager menu, expand the Universal Serial Bus controller section, and uninstall each of the USB ports. Then restart the computer to automatically reinstall the ports. If the problem persists, you may have to entirely replace the USB port.
The Troubleshooting Guide has a section on possible USB port errors you can consult for other possible answers.
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
When you look to usb port you see something broken? If yes, you must buy a usb port, unmount to remove the motherboard and change, you need soldering skills. If the usb port is not on the motherboard but instead on little board who connects by ribbons to motherboard, you can replace that board or repair.
If no, could be a soldering problem and you only need is solder again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mae Underwood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 528
