跳转到主内容
戴尔上网本包括Mini 10系列的维修和支持指南。
17 个问题 查看全部
A cabinet file necessary for installation cannot be trusted
A cabinet file necessary for installation cannot be trusted. Please verify the Cryptographic Services are enabled. When i tried to install directx i got this message " A cabinet file necessary for installation cannot be trusted.
How to solve this..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
5条评论
how to verify cryptographic services are enabled
please replay to hurryup
完成的
please help me
完成的
i have fixed on https://www.ahmedhub.us
完成的
@shahzaib khalil
Try this!
Set Cryptographic Services to automatic Set the Cryptographic Services to Automatic, and then try to install the program again. To set the Cryptographic Services to Automatic, follow these steps:
Start the Administrative Tools utility in Control Panel.
Double-click Services.
Right-click Cryptographic Services, and then click Properties.
Click Automatic for Startup type, and then click Start.
Refer: http://support.microsoft.com/kb/822798/ and follow all the methods listed in the KB article.
Man is the only animal that laughs and weeps; for he is the only animal that is struck with the difference between what things are and what they might of been.
完成的
mercy.the best wishes for you
完成的
添加一条评论
3个答案
已选择的解决方案
Hey Bro, I don't know if you still have issues with this but this is for anyone how is still experiencing this issue when trying to install DirectX.
I searched for hours and struggled to get this fixed, long story short I finally got it fixed!
Please try using the following link. Note: this is not a scam nor virus , it's from the official website (Microsoft)
https://www.microsoft.com/en-us/download...
Installing that fixed my issue.
1.Create an empty folder (The folder's name isn't important, just leave it blank for all I care)
2.Put the directx_Jun2010_redist.exe (That you just downloaded) into that empty folder.
3.Install/open the "directx_Jun2010_redist.exe"
4.Scroll through all the contents that were extracted, look for "DXSETUP.exe" and Install that.
5.Click through the on screen instructions and allow it to complete.
6.What are you still doing here you're DONE!! :)
这个答案有帮助吗?
得分 66
36条评论:
thanks, its work
完成的
I just registered to thank you. Your solution solved my problem after hours of struggling. Thank you very much!
完成的
完成的
Thanks alot bro..
It worked....
Legendary
完成的
Thank you very much. I had to register to thank you
完成的
显示更多的31条评论
添加一条评论
This is what I did and it worked!!!
1. navigate to \Windows\System32\directx\ or \Windows\SysWow64\directx
if you have Windows 7 x64.
2. Click on "organise" file menu, then "folder and search options" then
in the "View" tab check "show hidden files and folders" and then "ok"
3. websetup folder will be visible now. go in there and delete all
contents.
4. run "dxwebsetup" again.
Works for me under Windows 10 64bit.
这个答案有帮助吗?
得分 2
3条评论:
Thanks man!!!! i was going gray over here that really helped
完成的
Most welcome
完成的
When I try to run dxwebsetup I get some error about a cabinet file and cryptographic services
完成的
添加一条评论
ممنون در رفع مشکل من خیلی موثر شد.همیشه پر توان باشید.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Winkigreen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 73
总计 44,189
