Why is my audio not working?
I am trying to listen to music on my notebook but no luck. There is an error, it reads that there is another program using the audio.
The IBM ThinkPad X41 has built in speakers, which can make audio problems frustrating. Try taking plugging in a pair of headphones into you laptop's headphone jack. If you hear sound in the headphones, then the problem could be a hardware problem. If you do not hear sound in the headphones, try one or more of the following:
If this does not solve your problem, then a driver for the sound card may need to be reinstalled.
这个答案有帮助吗?
They're fixes that have helped other druggies resolve the Lenovo laptop no sound issue. Just work your way down the list until the problem is resolved.
You can start troubleshooting the laptop with no sound issue by following steps:
* Make sure to check your speaker and headphone connections for loose lines or the wrong jack.
* Try connecting your speaker or headphone device to a different harborage and see if this fixes the problem.
* Make sure the volume is audible
* occasionally you can’t hear sound from your speakers simply because the volume is mute or set too low.
To make sure the volume is audible
* Still, make sure to slide the volume bar to an audible position too, If there’s a volume control on the app you’re playing.
Set dereliction audio bias
Immaculately, when a new audio device is fitted, Windows will automatically set it as the dereliction audio playback device. But that’s not always the case and occasionally we’ll have to set dereliction bias manually.
Disable audio advancements
Audio advancements, as the name suggests, are features that allow for the loftiest sound dedication from your tackle. But depending on your configuration, they can also intrude on your system and detector sound problems. So we should disable audio advancements to see if it fixes the no sound on laptop problem.
这个答案有帮助吗?
Whenever you are unable to get the sound on lenovo computer. please install the earphone or speakers into your laptop. and then try to play something. lenovo laptop internal speakers not working but headphones are, please make these changes into your computer.
After that if lenovo laptop has no sound, you need to visit the lenovo store for more help.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 1,453
