跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Problem with USB after Updating the OS
My Apple MacBook Air MC233LL/A doesn't want to recognize any USB devices after I updated the OS software through standard Update tool. Nothing's working now, no mice could be recognized or any other USB (or mini-USB) device such External DVD-drive. When I plug something in, for ex., iPhone 3Gs, it shows that it's charging, but inside the OS nothing's recognized, no iTunes starts or whatever. How to shake the OS? Please advise on what to do with it, so USB could work again. Thank you very much.
P.S. before that Update everything worked well.
Update
Majesty, I did all things like you said. Man, u're a genious !! Everything's fine now. OS X has gone to its default settings after I removed and placed the battery back. Thanks for the tip! I really appreciate your tip. Thank you, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
BTW, does anybody know why LED-backlit doesn't work on Windows XP ? I've installed XP sp3 on my MBA, it seems that everything's working good: sound, video, touchpad (although it doesn't respond to OS X two-finger thing and etc). Please advise on both touchpad and backlit on Windows XP. Thank you.
完成的
添加一条评论
2个答案
已选择的解决方案
I would try zapping the PRAM and SMC. Restart holding Command, Option, and P, R keys simultaneously. That failing reset SMC by removing battery, remove the Mac from power supply and hold the power button for 25 seconds. Then start up normally. Hope this helps.
这个答案有帮助吗?
得分 3
1条评论:
Good start-if this fails try reinstalling the update. I had a case once where the update installed incorrectly. +
完成的
添加一条评论
The ports on my Mac A1150 fails to connect a USB device, connects and disconnects or is slow to recognize
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zanoza zanoza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,220
