跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
How to activate iPhone 7 home button without using finger
I just got an iPhone 7 and I commute via motorcycle Over 100 miles a day. I use a waterproof case that clamps to my handlebars to keep it in so I can view it, change music, etc. The new home button does not work through the case. I know the phone is waterproof and I don't have a problem cutting a hole in the case if I have to. But is there any way to unlock the phone without taking my gloves off? Or is there any material that I could put over the home button inside the case that would activate it so I could enter my passcode?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Hi this article discusses this subject, as far as I'm aware it needs skin contact to work.
hope it helps
这个答案有帮助吗?
得分 0
添加一条评论
Any glove that would work with the touchscreen will work with the iPhone 7 home button. It does not need direct skin contact. All that is needed is for the gloves to have capacitive or "conductive" thread sewn into the finger and they will work. They won't unlock a Touch ID enabled device (since it's not your fingerprint) but it will open the device.
https://rideapart.com/articles/best-touc...
这个答案有帮助吗?
得分 0
添加一条评论
Mix a little graphite powder with super glue. Spread the paste on the inside of the pouch at the position of the on-button. Wait until the glue dries completely, as super glue reacts with phone plastic parts. You still have to enter your password to open the phone.
Hans
这个答案有帮助吗?
得分 0
添加一条评论
My iPhone 7 finger tip
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Bumgarner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 3,133
