跳转到主内容
提供各种SEGA(世嘉)游戏主机的维修资料。 以游戏主机开发起家的世嘉,已于2001年1月宣布转型为纯游戏软件开发商。
Graphic and Sound problems!
HeyHo,
I bought a used Sega Master system 1 Power Base, PAL with antenna cable and the game "Alex Kidd in Shinobi World".
Well, the system works fine but there is a deep buzzing noise at the background. The noise does also change pitch from normal to low, to high....
And the graphics are really messed up. There are huge black transparent scanlines from the bottom to the top of the screen. And at the point where the scanline is, the game changes to black and White... oÔ
I Tried:
  • Another Antenna cable (From NES/Famicom)
    • Nothing Happened. Same Errors.
  • I soldered in a A/V Connector.
    • Same Problems with graphics, but no sound (Allthough I did solder correctly.)
  • I Tried to hook the Game system on a CRT TV (Mine is Flat)
    • Still the same problem...
  • I cleaned up the whole System. Every contact of every connector was cleaned.
    • Of course the error still appears.
  • I Cleaned the Game Module.
    • Same Problem -.-
  • I Opened the system, but every cap, every contact and so on was fine.
I hope you can help me or make a suggestion.
Thanks folks,
Kentsfield
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Wow. That's a little out of my league. Try these places for some extra help. I'm sorry, wish I could help you further.
Genesis A/V Pinout
Genesis Mod Forums
Master System Scart pinout
Good luck!
==Update==
Maybe these will help too.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, man!
You're Awesome!
With this schematic I can try to fix this problem.
Anybody else got suggestions?
完成的
添加一条评论
It is the capacitors. Common issue. I sell them on ebay. Look up sega master system capacitors
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kentsfield 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 5,605
