Why can’t my tablet connect to WIFI?
I can not get my tablet to connect to the WIFI
Hi @Michael Emery,
Can you access the network when the tablet is right next to the router?
If so try disabling the tablet’s WiFi’s minimum power consumption setting. Go to Device Manager > Network Adapters > right click Broadcom Wireless > Properties > Advanced > minimum power consumption and see if that helps. (not quite sure if it is called minimum power or something similar)
这个答案有帮助吗?
Make sure the WIFI is enabled. If this does not work perform a hard reset. If the problem still persists check your router or modem to see that they are properly connected.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 372
It not the network as i have reset it and all other devices have picked up the network
由 Michael Emery 完成的
