跳转到主内容
The HTC Desire is the first smartphone of the Desire series developed by HTC.
37 个问题 查看全部
问题已关闭
My speaker is not workin what should I do?
hi everyone my back-speakers on my desire is not working at all after 2 weeks from taking the phone the voice of the songs is crashes and some times when i open a song nothing happen the problem in my speaker but i don't know what to do
so please give me a solution and thanks to everyone
sorry for my poor English
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I had this problem 2 months ago. I found, serching the Internet, that this is caused from a bad contact of the speaker.
The following solution worked for me:
I removed the battery and I used a small piece of black insulating tape to "glue" the bottom of the laudspeaker (which is closer to the battery) to the phone case beneath the battery. If you use a large piece of tape the speaker may be covered and you will hear nothing.
It's so simple and you can try it.
Cheers
Giannis
这个答案有帮助吗?
得分 0
添加一条评论
Hola soy luis ablo español Lo que pasa es que mi HTC que compré salió con problema de que se apaga constante mente luego se prende Lo lleve al servicio técnico de la tienda movistar y sólo Lo actualizaron y no pasó nada se sige apagando
这个答案有帮助吗?
得分 0
添加一条评论
If you are quite certain that there isn't moisture damage to the phone, this problem mostly occurs because the coils on the loud speaker aren't connecting properly to the cores on the circuit board.
There is a more permanent solution. Due note: Inspect for any form of corrosion or moisture damage while you have this part of the phone open.
  • If you can manage to removed the housing directly beneath the battery, you will find the loud speaker is attached to it.
  • The two coils on the speaker tend to retract over time.
  • Take proper tweezers and gently stretch out each coil.
  • Reassemble the phone and test.
This normally does the job on this specific model.
这个答案有帮助吗?
得分 0
1条评论:
I remove the battery 2 times press on speaker and when i restart it start working :)
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 13,570
