跳转到主内容
A touchscreen GPS released in February 2012 by Garmin with custom position of interests and junction view. The screen size is 4.3" diagonally with 480x272 resolution.
6 个问题 查看全部
Why will my nuvi 2455LMT not detect a GPS signal?
My device will turn on, but it will not detect a GPS signal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  • The most common cause of signal failure is the environment around the GPS
  • Make sure you are not in a parking garage, surrounded by trees or overhangs and at a standstill when the Garmin GPS is turned on.
  • The longest amount of time it takes the GPS to acquire a signal is 5 minutes. These instances occur when you travel more than 500 miles with the GPS turned off or if you are indoors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dakota Caldwell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 116
