跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Excessive heat and a decrease in performance
Hey,
Recently my galaxy s6 fell out of my pocket into a puddle. Everything seems to work okay, but I found that the battery is emitting an excessive amount of heat and I've experienced quite a dramatic drop in performance. Sometimes I'll press the power button and it will take 20 seconds for it to work. I kept the phone on a towel after it got wet for 72hrs and everything seemed to work find for about a day. Anyone know how to resolve this or share possible reasons why this would happen?
Cheers :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here is a great video that explains the "why":
https://www.youtube.com/watch?v=DsDpALKQ...
There are countless tiny components inside your phone that corrode nearly immediately once your phone gets wet. The heat issue is a serious one since your phone does have a lipo battery and the battery can explode and catch fire. The best case scenario for you would be a bad battery. That's a pretty straight forward fix. Otherwise, it will be damage to the charging system which would require micro soldering skills and tools.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply. The heat is mostly in the top region of the phone and I can hear a clacking sound when I shake the phone (not sure if thats normal). As for a fix for the battery, I have heard that it's extremely hard to disassemble my particular phone. I wouldn't be able to get it repaired by Samsung because water damage isn't covered under warranty. It has been a few days and the phone hasn't gotten any worse, though I assume the phone will slowly degrade over time. Any thoughts on how to get it diagnosed and repaired? Cheers
完成的
Samsung phones are among the worst to work on now. It takes some practice to be able to open them without breaking something. If you don't want to take it on yourself, find a reputable repair shop close to you. They will be able to diagnose it for sure.
完成的
添加一条评论
添加你的答案
Connor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 106
