跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Battery won't charge - Lightning connector or Logicboard broken?
Dear Fixers!
My friend owns an iPhone 6s Plus. A few weeks ago, his battery wouldn't charge anymore, so I ordered a new one from iFixit, and everything worked fine again.
Now, the same symptoms occur again: The iPhone gets stuck in a Reboot-Loop, it won't get recognized by iTunes when put into DFU-Mode and the one time I succeeded turning it on it wouldn't charge to more than 1% (so basically nothing).
Now is the point that I don't think that I had bad luck with both the batteries (the Apple one and die iFixit one), so I suspect either the Lightning connector being broken in some way so that it "destroys" the battery over time or the Logicboard having a comparable issue.
No the question: Do you think it might be the connector? Do you think it's worth a try to change the Lightning connector AND a new battery? How high is the probability that the Logicboard is broken and the phone therefore "unfixable"?
Thanks guys!
Alex
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It ain't broke til you see smoke!
I would start with a new Lightning connector. It wouldn't be uncommon for that to be at fault and its a cheap and easy fix. If that doesn't fix it, its almost certainly the Power IC (Tristary) chip. That's a job for someone with microsoldering skills and tools.
So start with the easy thing: the Lightning port. Its about a 50/50 shot on that being the issue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alexander Eyring 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 437
